dome light does not work?
dome light works when passenger door is opened but not when drivers door is opened? checked button it is ok.
steven white , If passenger door puts the light on and you tested the light button on the drivers door and found it to be good, you will have to trace and check the plug/wires from driver door switch for corrosion, bad grounding or bad/damaged/open wire. Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 474
