Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52 Questions View all
Built-in flash will not pop up when required. error message appears
Built-in flash will not pop up when required. error message appears.
Camera may have been dropped while in its case. (Report from grandchild is sketchy)
It will take pictures outdoors when flash is not called for and indoors in sports mode.
Score 2
Add a comment
had a similar issue on 40d. brought it to repair shop and the guy just gently helped the flash to pop up with a fingernail and it jumped right out.
apparently the mechanics are very subtle a even tiny drop of something sticky might cause that the flash doesn't pop out. then the error message comes.
wouldn't use much force though, might be other issue
Add a comment
I have this problem too. I can manually pull the flash up but have to do it every time I take an inside picture. Any suggestions on how to permanently fix?
Add a comment
I had the same trouble with my T3-i. I used a small file to enlarge the hole that the clasp uses to hold the flash down. I did this extremely carefully as to not remove too much of the plastic, so that the flash would still be held down when not in use. I did this about 3 years ago and it has not caused me any trouble after the repair and it only took a few swipes of a file.
Add a comment
Add your answer
Robert Lauritsen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 465
