0
Score
Tommy
Asked
Why does my screen not work after replacing it?
Hi
I dropped my Iphone on rocks, the LCD panel brok and i replaced it with the front panel kit (the front panel and LCD screen kit). i instaled it and pluged it to recharge abouth 1 hour and it dont whant to start. notting react wen i hold the power botton. i look at all my conections 3 times and it still dosen't work. plese help me.
Thank you
Tommy
Score
Alex Jansen
2.6k
Answered
Accepted Answer
If your LCD broke, the front panel kit is not going to help; you will need a Replacement LCD
4
Score
Answered
I realize that this thread is quite old, but I may have found an answer. If the iPhone is turned on before the LCD and digitizer are physically connected, then LCD and digitizer are not found by OS, and they never turn on, even if connected later.
Solution: disassemble the phone, disconnect the circuit board, then reassemble, taking caution not to press the power button before connecting LCD.
Possible solution: hold power and home button together to reset the phone.
0
Score
pollytinto
34k
Answered
have you checked ALL your connections-1-6 and the battery contacts etc. Go back and check again.
If you have done all this, you may have damaged more than just the screen. the clue to what may have broken will be in the area of most damage to the phone. start looking in that place
0
Score
N Solis
Answered
I have the same issue - Screen won't display anything after replacing the screen and digitizer. However, I do hear a the charging sound when i plug the iphone to the wall. I check the connection. They seems to be all connected. However, i am not sure how to check that the 2 wires from the digitizer are actually connecting to the mother board. Are they supposed to snap into place? It's difficult for me to check if the wires are lined up with the mother board when I intall the mother board and battery back into the assembly. Any idea how to check this connection properly?
Installing iPhone 3GS Display Assembly follow this to check on your connections. I think 1 and 2 snap, 3 is a ribbon cable that requires you to loosen the small clip to remove it. Good luck.
0
Score
pierrick
Answered
bonjour a tous.alors suite a une chute,ma vitre été casser,j ai remplacer la vitre et enlever le lcd pour le demontage quand je l ai remonter le téléphone ne marcher plus il y avais juste le son j ai essayer de le brancher a itunes,faire la manip arret bouton du bas pendant 10s tjs rien,charger rien alors je l ai laisser de coté trois jour et en le rechargeant il c 'est remis a marcher en esperant que ca va vous aider.
Je suis utilisant un navigateur internet traducteur j'espère donc ce sort correctement! Vous devez vérifier à nouveau et nettoyer toutes les connexions des iphone, y compris ceux de la batterie et USB dock connexion. si ce n'est pas rendre le iphone pouvoir sur, vous devez vous connecter à itunes et essayer une restauration. cela peut donner un code d'erreur qui peut nous aider à réduire le problème.
0
Score
Answered
Does it react to you plugging it in and charging it? Does the screen light up? does it make sounds?
Gabe,
no, there is no sound or reaction wen i plug it and the screen don't light up tommy
Tommy,
Was the phone working even with the cracked front panel before you did the screen replacement?
Scott Head,
no because the lcd was cracked, that why i buy the front panel kit. when the lcd crack, the iphone screen stop working and the iphone did not make any more sounds. Tommy
Tommy,
