Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
51 Questions View all
Computer power goes off after sometime on
After turning on and using my laptop for sometime, I just hear a clicking sound and it turns off completedly.
I then try tu turn it back on, but it clicks and turns off.
I have to leave it like overnight to turn back on, but it will only remain on sometime and the same would iccur again.
1 Comment:
Hi, Can you hear if the fan running? Can you feel the air coming out of the fan vents? Are the vents clear and not blocked?
by
Add a comment
1 Answer
Sounds to me like it might be a heat problem.
I would recommend using a program like AIDA64 (https://www.aida64.com/downloads) to see what temperature the CPU is running at. AIDA64 also allows you to so a stress test (Force your CPU to 100% load). You can then keep an eye on the temperature to make sure it doesn't go over what the CPU manufacturer recommends. I would stay under 70C
Add a comment
Add your answer
Fran Tor16 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 66
