1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Help finding refdes for cap
Would somebody be able to help me identify this component? I think I found it on the schematic but I'm not sure which capacitor it is since there are several surrounding the CSD58872Q5D. I didn't highlight it in the picture but hopefully it is obvious (the blown one). Thanks! This is a A1466 2012 MacBook Air btw.
Score 1
3 Comments
I think I narrowed it down to C7553 and C7115 (I think, don't have the schematic in front of me) both have the same attributes 62uf, 20%, 11v, poly, case b. So maybe that is enough to find a replacement. Feel free to correct me in case somebody finds this later but that is what I'm going with. Thanks.
by
*C7113 thanks Reece
by
Where can one buy one of these? I have the same issue with mac book air
by
Add a comment
Chosen Solution
C7513 if it is a 820-3209, and the area above I/O port and bottom right of CPU. Get a board view file for your board to double check
Score 2
Add a comment
@cmp2488 the failed component is reference designator C7513 which is a 62UF 11V 20% Poly capacitor in a Case-B package.
It will help tremendously if you always give the 820-XXXX of the logic board you are working on. Also make it a practice to post an image of the whole board with the location of the failed component marked. That way it is not like looking for a needle in a haystack :-)
Score 1
5 Comments:
Thanks. My first post so wasn't sure. Will do in the future :-).
by
Do you think this would be a replacement that would work? I wasn't able to find one with the exact specs. http://www.mouser.com/Search/m_ProductDe...
Thanks again!
by
The reason for the details is because it may help someone else down the line. Not everybody is fortunate enough to have the proper schematic/boardview etc. for this model. So your question and the subsequent answers may come in handy to help others. The main reason for the existence of ifixit :-)
That cap might work since it has the same values. It'll be an improved over the one you currently have on your board.
by
Thanks again. I'll see if I can amend my question with those details.
by
@cmp2488 no worries now. Reece identified your board and we're good. Just a consideration for the next time. No big deal really.
by
Add a comment
Add your answer
Craig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 390
