Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Questions View all
I restore my iPod with itunes,dont have power conector
What can i do, i restore my ipod with itunes, he ask me to plug it to the wall but i dont have the power conection, i just have the USB cable.. is there any way to make breath my ipod again?
Add a comment
Chosen Solution
blindmiror, can you elaborate a little? Itunes requested that you plug the iPod into a wall charger? Is it possible that it is referring to a firewire connection? I had a similar issue with a 3rd Gen that needs firwire to charge but USB for data sync. May be you can post what iTunes is requesting so that I can try to help you further to figure this out. Good luck.
Score 1
4 Comments:
Thanks oldturkey yes my problem is that after restoring my ipod with itunesitunes ask me to plug it in the wall to the electricity but i dont have the devices, to plug it to the wall, i was using just the usb cable and now the computer and itunes are not able to see the ipod. thank you very much
by
Okay blindmirror just did a bit more research. It is common for the older iPod to have to be connected to a wall charger as part of the restore process. It will finish updating the restore when you plug it to an external power supply....hope this helps you to get your iPod working. http://www.wikihow.com/Restore-an-iPod
good luck
by
@oldturkey03 so yea I know that it is 2019 but I have made my dreams came true and got iPod 4th gen. And I got same issue, I have ordered firewire cable but I am still missing power adapter? Do you think that it will be enough to connect it to working ibook?
by
Spamm3r should be okay for as long as it is Firewire. It may still require a AC adapter to complete but you can’t hurt it trying
by
Add a comment
Add a comment
Add your answer
blindmirror will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 1,079
