Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Keyboard Keys "Q" to "O" not working after carrying in Backpack
Hi!
For the last month after carrying my Macbook Air in my backpack the Keys q to o are not functional.
I have to repeatedly push them very hard and often until they work again.
I suspect a bad contact somewhere, any ideas where?
It's just these Keys, "P" for example always works as intended.
Will a Keyboard replacement solve this problem?
Thanks for the Help.
Greetings
Hallo!
Seit etwa einem Monat funktionieren die Tasten "Q" bis "O" nicht mehr nachdem ich das Macbook im Rucksack hatte. Ich muss oft und sehr fest alle Tasten betätigen bis diese wieder funktionieren. Ich vermute irgendwo einen Wackelkontakt, habt ihr Ideen wo das sein könnte? Es sind nur diese Tasten, "P" funktioniert zum Beispiel immer.
Hilft ein Austauschen des Keyboards gegen dieses Problem?
Danke für die Hilfe,
Liebe Grüße
Score 1
Add a comment
1 Answer
Chosen Solution
Yes, will most likely be a keyboard issue. Buy a new one (around 10$) and plug it in to test it first, since it can rarely be an issue caused by a liquid damaged keyboard connector, on the trackpad board. If it works fine, replace it. Search on Youtube "a1369 keyboard replacement" first though, there are rivets you will have to remove and replace with screws, so check to make sure you will be able to do the repair before ripping the old keyboard out :)
Score 3
3 Comments:
Thanks a lot, looks like a lot of work though
by
There is a bit of work involved, would recommend taking it to a local shop who does these without replacing the whole palmrest
by
I have the exact same problem with a 2015 MacBook Air 13" which I bought second hand less than a week ago.
Not happy
by
Add a comment
Add your answer
Stephan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,724
