The LG G Pad Tablet 7.0 was released in 2014, it is an Android based produced by LG. This device is the first produced tablet with a 7 inch screen and a 1.2 GHz Quad-core processor. Model number LG-V400.
14 Questions View all
Why cant I get external speakers tp work? A headset will work,
My speakers work fine. When I plug a headset onto the headset jack, the volume transfers to the headset and not thru the 7.0 pad, as it should. When I plug an external speaker set into the jack, nothing happens. I cant get the volume thru the external speakers.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
Are the external speakers 'self powered'? The audio amplifier in the tablet is designed to supply power suitable to drive earphones not external speakers.
If your external speakers are not powered try connecting the audio output from the earphone socket of the phone to the input of an audio amplifier to which your speakers are attached. (Use a stereo audio cable with suitable connectors, i.e. 3.5mm (1/4") plug for the tablet end and whatever input connection type you require for the amp e.g. RCA connectors, 3.5mm (1/4") plug etc.
Score 3
Add a comment
Add your answer
Bill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 214
