Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Why does my MacBook Pro shutdown when the battery is between 50-30%?
My MacBook Pro 13" 2009 Unibody shuts down randomly. I purchased it from a friend. I noticed the battery needed to be serviced and the body below the keyboard would get hot, so I got a new one installed at a local Mac repair shop. New battery is great, low cycle count. Heat issue was better. It even charges up to 100% percent no problem. But when it is off the charger and goes down to say below 50% it will automatically shutdown. I plug the magsafe back in and it boots up. Sometimes I do notice it can get down to below 20% and then shut down. What do you guys think? A battery or logic board problem? Thank you in advance for your help!
Score 3
1 Comment
Had a similar issue when unplugged at 55%. It was fixed by resetting with:
https://apple.stackexchange.com/question...
Take anything you read with a grain of salt.
by
Add a comment
Chosen Solution
@boogiexl ,Eddie. Checked a couple forums and found this, Link 1,2 You can try a battery calibration or Link 3 Reset Mac SMC (System Management Controller) use this reset when experiencing power management and battery problems: Mac isn’t turning on, sleep isn’t working, random shutdowns and reboots, battery isn’t charging, Good luck.
http://www.makeuseof.com/tag/calibrate-m...
http://www.tomsguide.com/faq/id-2349626/...
http://osxdaily.com/2010/03/24/when-and-...
https://support.apple.com/en-ca/HT201295
Score 2
Add a comment
As stated above, try a SMC Reset. If there is no change. Try reinstalling your OS and Verifying all Updates are applied. If issues still occur, have an Apple store or service provider run a MRI test, there is chance that the battery is not below the FFC % yet still causing shutdown like failure.
Good Luck,
Henri
Lead Service Technician
MacSuperStore, Santa Barbara
Add a comment
Add your answer
Eddie Bugayong Jr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 18,827
