An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Questions View all
Accessing Service Manual referred to in tear down section
In the intro to the teardown section there is a reference to a service manual which appears active. When I click on it I am simply taken back to the first page. How can I access this service manual??
1 Comment
@staz staz @lpfaff1 most likely because you are looking at Student teardowns. Could be that they are unfinished, or will not get finished. Isn't Starbucks Barista not just a rebranded Philips Saeco machine? try to do a search on those.
by
Add a comment
Chosen Solution
@staz , peter, I get the same results when I key on the service manual , either it is still in the works or there is not a service manual, there is plenty of other info./guides on the Barista, from tear downs, testing items to trouble shooting, hopefully they can help. I did try a google search also and did not find a service manual. If you have a particular problem, post your problem as a new question with all the info. and one of the ifixit volunteers may be able to help. Good luck.
Added a couple links below that may help.
https://www.espressocare.com/products/st...
https://espressodolce.ca/parts-diagrams/...
Score 2
Add a comment
@staz @lpfaff1 most likely because you are looking at Student teardowns. Could be that they are unfinished, or will not get finished. So, there may not be a service manual. Isn't Starbucks Barista not just a rebranded Philips Saeco machine? Try to do a search on those.This, combined with some of the students work, may be a start for you.
Score 1
Add a comment
There is no official repair manual for this machine; if ifixit is working on one it hasn't been posted yet.
Add a comment
Add your answer
peter stazicker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 141
