Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 Questions View all
Why dont my reverse lights work when I put it in reverse?
My reverse lights havent worked since i changed steering columns. So that i had tilt the other day i plugged in a trailer and they suddenly started working since i dont know where their activated from its hard to track down the problem
Score 1
Add a comment
1 Answer
Chosen Solution
Trikkidick West, since the reverse lights went out after changing column probable bad wire/plug connection at the park,neutral,reverse bulb switch which is attached to lower part of steering column. Strange thing is you say they are working now after plugging in trailer plug so you should also follow that harness and check for shorted/damaged wires, also make sure all grounds are clean and tight. Link below shows a diagram of switch on column, switch is #3 on diagram. Good luck.
http://www.truckforum.org/threads/backup...
Score 4
Add a comment
Add your answer
Trikkidick West will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 819
