0
Score
Avatar
David Jarrett
Asked
Battery, charger, or DC in board defective?
History
My 14" i-Book G4 1.33 GHz will function fine with the A/C adapter attached, but the battery will not charge. I had to buy an different adapter from the one that came with the machine (on eBay), and it does not have the colored lights on the barrel connector, so I can't tell if it's charging. The adapter is marked "Macintosh PowerBook ibook 45W AC Adapter"and says it was from Apple Computer in Cupertino. It gets hot, so it's getting current, and the battery icon on the machine shows that it's plugged in, but the battery charge remains at 61% regardless of whether the computer is on or has been turned off for awhile. When I disconnected the charger to check the battery, the indicator on it showed four green lights, but it lost 1% of its charge in about 2 minutes. What do you all think? Battery? Charger? Something else?
Thanks in advance,
Dave
Edited by
Post Answer
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
I would replace the battery connector, here's how: Installing iBook G4 14" 933 MHz-1.33 GHz Battery Connector
Here's the part: Here's the part: iBook G4 14" Battery Connector
Edited by
Product Image
Connects battery to logic board — 8 available at 9.95 each.
good answer +
rj713,
0
Score
Avatar
rab777hp
12.6k
Answered
PermalinkHistory
Download coconutbattery and check the health of your battery, I'm betting it's that. You can get a replacement battery here.
Edited by
Product Image
Upgrade your aging battery — Currently out of stock.
No -- Coconut Battery shows battery health is fine.
David Jarrett,
0
Score
Avatar
Cole
Answered
PermalinkHistory
I have the same problem. I replaced the battery connector per Mayer's recommendation but it still isn't charging - quite an interesting experience though getting deep inside the laptop.
Mayer, any other recommendations?
Adding questions to an existing question is a good way for it not to get seen. If you have a question always start a new one to make sure people see it.
mayer,
0
Score
Avatar
mauriespierre
Answered
PermalinkHistory
Maybe the adapter isn't geting enough juice out. The original Ibook G4 14" charger is a 65W... Maybe 45 isn't enough to charge the battery (I remember reading there were issues like that with the "airplane adapter" : enough juice to run the mac, but not to charge it)
My 2 cents....
Good luck! :)
Add Your Answer
