How do I get out of guest mode?
I somehow went into guest mode, but I can't find a prompt under security settings to turn off guest mode.
Qs: how to come out of guest mode on BLU 5R?
Answer:
Option 1) We need to contact BLU and they would probably share an APP that we need to install that solves the problem.
OR
Option 2) I have done that work for you...
Check out my blog to see the solution and also find a link to download the APK that BLU shared.
hey how do i install the apk to my phone?
yes thank you it worked
Thnk u so so much
OMG...... I'm so happy I'm out of guest mode...Thnx so so much...Well Appreciated
Wowww.... at last i get back all my call history and fotos... Thanks you very much.
It's in Settings>Security>Guest mode
just un-check the box! It's not obvious and took me an embarrassingly long time to figure out what that weird icon was
Can you add a screenshot?
http://imgur.com/gallery/toInB
Here's a few!
My settings haven't guest mode
There is no such thing in my settings.
there is no Guest Mode option in Security on my Blu Vivo 5R.
Hi everyone,
Quick and easy fix. All you need to do is download and install this .apk file (search 'stewbanga') Disable Guest Mode Blu Vivo 5R and you will be good to go. No factory reset, nor reboot required.
Hope this helps!
You get in to guest mode by using a 3 finger swipe up to unlock the phone. I suspect that a 3 finger swipe up or swipe down will get you out
Hi everyone i have the perfect way to exit guest mode or get in, all u need to do is to download apk that controll this mode it called: GuestModeDoctor.apk
U need to google it and install and it will work, i have vivo r5 and it worked!!
I have tryed this several times and it just won't give me the option.
I used it a while ago and worked fine.
When I open the APK app, just shows me info about my phone I don't need? Can u help me after I open the APK app, what happens next?
Ok so I had this problem too.
I went to settings at at the bottom clicked on “about device”
Then click wireless update, and waited for 30 minutes whilst it installed 70 updates.
After that I went it to settings at at the top the it is!! Guest mode uncheck and it's all back to normal, albeit with a few updates…
Hope this helps
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 32,320
17 Comments
Oh I'm so thank you
by Ahmed
miranda5749, please assist me here...i some how fail to get the proper apk file site....so how do i download it
by Meshack Reuben
Plz help me .... I have same problem entered in guest mode unable to come.out ofit
by Sandhya shakram
I am having the same issues
by djkartist54
theres no guest mode checkbox for me in setting would you mind helping me?
by NazhifM
Show 12 more comments
