Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 Questions View all
Why doesn't my iBook G4 recognize my Airport extreme card?
I have three Apple products with the same Airport Extreme cards installed in them.
The machines are a 1.5 GHz Mac Mini G4, a 1.67 GHz PowerBook G4, and a 1.33GHz iBook g4.
The Airport Cards are all as follows:
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x14E4, 0x4318)
Wireless Card Locale: USA
Wireless Card Firmware Version: Broadcom BCM43xx 1.0 (4.170.25.8)
Current Wireless Network: wireless
Wireless Channel: 6
All computers easily access a Netgear router except the iBook.
It does not recognize the Airport card that is installed.
Has anyone encountered this problem, and is there a solution?
Incidentally, all computers connect via channel 11 except the iBook which indicates channel 6 as shown above.
Thanks in advance,
Craig
Score 1
Add a comment
1 Answer
Chosen Solution
Look under the Apple in the upper left hand corner to "About this mac". Hit the more info button. Go to Network -> Airport and see if your machine sees the card. If not switch it with a known good one. Are you sure all three machines use the same card? What's the part number? Is it this card: [linked product missing or disabled: IF183-054]
Score 3
1 Comment:
agreed +
by
Add a comment
Add your answer
Craig Pemberton will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 2,139
