Why won’t my device turn on?
There are no signs of power on the device, no lights or sounds are seen or heard while trying to power up the device.
Hi @devontaroofe ,
It sounds like your device may not be charging. This could be from a bad battery, damaged charging port, or bad charging cord most likely. You should be able to determine if it is the battery or charging cord fairly easily, the charging port may require more technical know how, but if we can determine which one is the culprit we should be able to help you find a solution.
If you have another HP laptop, see if the cord for yours will charge it (be sure they have the same tip).
Try swapping the battery with a new one. There are a few options on Amazon.com. Which simplifies returning it if the swap does not resolve the issue.
If it's not either of those, you would want to check the charging port itself for visible physical damage. Is the plug snug and secure or does it feel loose and possibly broken...?
@jadeetk421 this is a student assignment. Tread lightly ;-)
@oldturkey03 ?? Are you on Pro Talk? Can you DM me?
Hey Devonta,
The problem may be coming from a faulty batter or maybe a faulty power adapter. If you go to this troubleshooting guide here .It will help you determine the source of the problem.
My Compaq laptop shows charging light but won't power on.
What will i do
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 16
All Time: 1,228
