Laptops produced by Fujitsu.
74 Questions View all
screen turn on and off when I touch the laptop lifebook s751
screen turning on and off when i touch the laptop mostly on the body, everything is working ok even when i touch the screen ,, so i dont think so its about screen.. i tried to open it up but all wires or sockets where in the right place.. so i wonder what it might be.. should i just change the main board?
what you think guys?
thanks
Add a comment
1 Answer
Chosen Solution
first u need to check the connector cable from monitor to the board it's likely the issue here , maybe not connected well from both side u better check or corrupted need a replacement.
1 Comment:
i checked everything, i disassembled down to the main board, everything looks very ok. ports are solid, but when i push some where around to the CPU fan area picture will gone, and i have to shout down and turn on again. i tested the main board alone to be sure nothing is shorting between sink and main board, but still same result..
any idea?
Thanks
by
Add a comment
Add your answer
frankdez will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 21
All Time: 102
