Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
89 Questions View all
Why is there an led light shining through the phone speaker slot?
My phone has an led light shining through the phone speaker slot on the front. It has nothing to do with the screen or the rear leds for the phone's camera. It never shuts off and is on whether the phone is on or off.
Score 3
2 Comments
Today I mistakenly fall my phone and it gets off and a mysterious led light turns on and my phone doesn't gets start what should I
by
how did you fix it?
by
Add a comment
Chosen Solution
Hi,
Apparently Moto G3s (plus other Moto models) do have a LED behind the speaker grill.
http://www.techdroider.com/2015/08/moto-...
It supposedly cannot be enabled, but it can if the phone has been rooted.
There is this link to a poor audio You Tube video which shows one app (of a few apps) that have been developed to utilize it as a notification tool for when the screen is not working.
https://www.youtube.com/watch?v=ZuhV90iW...
There are also reports of the LED turning on after the phone (non rooted) has been upgraded to Android Marshmallow, but apparently it is random, the reason for it is unknown and it cannot be turned off.
I do not know if this will work but if it bothers you, you could try doing a backup of your phone and then performing a hard reset to see if it clears the problem and then restore your phone using the backup you made.
Score 1
Add a comment
The charging port broke on my Moto G3, the battery drained completely and it sat dead until I got the replacement part a month later. After changing the port I plugged it in and...the mysterious LED behind the speaker came on. I switched chargers, it stayed on. After 5 minutes charging, the LED went away, just as the screen, which until now remained dark, turned on showing 0% battery and charging. When a battery is completely drained it can enter a state where it has some difficulty accepting charge, if the battery is still good this remedies itself after a little while. So I'm going to guess that one of the functions of this LED is a low level detection of whether the battery is accepting charge properly. The age of your battery, the condition of your charger, and a variety of other factors can probably set this off.
Score 1
1 Comment:
I think I can confirm Carcia Family's assessment. Just replaced the screen and battery and got the same black screen and white led when attempting to s=charge the phone. I went back in to make sure the battery terminals were properly seated (apparently they weren't). After that, pressin the power button while charging activates the screen with the charging indicator displayed, and no light. It must be an indicator to let you know the battery isn't charging.
by
Add a comment
Try draining down your phone charge to 0.0% .. and plug the charger.. may be LED will get turned off after a bit.
Add a comment
Today I had taken my phone to the bathroom and exposed it to the shower
It lit up I think it acts as an indicator to sow that water is around or something
1 Comment:
I had the same thing; I was listening to music & taking a shower then when I came out I noticed the LED on
by
Add a comment
so i got my screen repaired not to long ago, i was playing on my phone & it’s dark in my room & i just realized there is light coming from inside my earspeaker, i have an iPhone Xr if you have any way to help me please respond
Add a comment
Add your answer
Nate Huff will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 25,886
