Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
118 Questions View all
How do I fix a loose charging port?
I have a problem that you might be able to help me with. My phone USB port I think that's what it's called well is loose and my phone doesn't charge well it charges very slowly but I have to maneuver around the cord is there anything I can do to fix it
Score 6
2 Comments
I had this problem too. The solution was to buy a new good quality charger. It's probably not the device but the plug.
by
my dad has a alcatel one touch and we had to hold the charger in the phone and now it will not charge no more what is wrong
by
Add a comment
Chosen Solution
Briggette, sounds like charging port is warn/damaged, you may need a new port. Drop into any small computer/cell phone repair shop and have them take a look,diagnose and estimate repair. I will post a link for you to see how the port is changed if you would like to try and change yourself.
Check the attached link,instruction and guide, Good luck
https://www.youtube.com/watch?v=VQekmZQr...
Score 4
1 Comment:
Can you use any charger port or does it have to be from the same kind of phone
by
Add a comment
Broken port most likely .
1 Comment:
Mine broke going in to charge almost like they werwnr seated properly inside the tablet cuz I felt it go further inside which made it impossible to make connection to charge at all without breaking it open fig out why it came loose and I read some place it's a known issue no less good times lol
by
Add a comment
Add your answer
Briggette Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 29,688
