Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Dropped iPhone 3G not responding
After being dropped, my iPhone fails to respond. The drop was bad enough that the mute button broke. At first, I could get the Apple logo after pressing on the home & power button (but it would not reboot). Now, even that doesn't work!
I opened it up and check on all the usual contacts and all appear to be OK.
Anyone have any ideas? Apple won't even look at such an old model - their solution is, of course, buy a new one.
Add a comment
1 Answer
If you plug it into a charger, do you get a battery icon or Apple logo on the screen? If you plug it into a computer, does the computer see it?
A drop that had enough force to knock out the mute button on an iPhone 3 had a lot of force. Also, your solder is going to be very brittle by now and easily damage.
There are a whole list of things that it could be, but we need some more information to narrow it down. Please answer the questions above and we'll try to point you in the right direction.
1 Comment:
Thanks fot this answer.
I have already posted this comment but am not sure that it has been received ( I can't see it!)
After the fall, I tried to activate the phone using the computer and keeping the home & power buttons depressed. The first couple of times, the Apple logo appeared but the phone did not reboot. Trying again the logi no longer appeared and there was no response apart from the occasional flimmering of the screen. The computer does not recognise it.
Examination of the 6 numbered contacts and the ribbon conections shows no obvious problems.
by
Add a comment
Add your answer
Christopher Gray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 54
