2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
MBP can't boot (no chime, no display)
Hello Everyone,
Since three days, my Macbook pro is refusing to boot : I can see the front LED, ear the Superdrive start, ventilators and HD are started too; Then 10 seconds after, it reboots and does the same.
Display stays black, no chime too.
I replaced the two RAM sticks, tried SMC reset and PRAM reset (as I'm not even getting a grey screen, I think I tried that for nothing). I also replaced the Hard drive and disconnected the Superdrive.
Nothing! It keeps rebooting again and again...
Does someone have already seen that?
Thanks
Alex
Add a comment
Most Helpful Answer
What are you using to power the mac when this happens? This sounds like a power issue to me. Try removing the battery and powering off an AC adapter only. Make sure you are using an 85 Watt AC Adapter and not a 65W or less.
Score 1
2 Comments:
Tried with two different 85W adapter. Still same issue.
Thanks for your help !
by
Add a comment
Try booting into Safe Mose by booting with the shift key held down.
Next try
+ booting from another LEOPARD device and applying the latest system update.
+ repairing permissions via disk utility
Score 1
2 Comments:
Safe mode is unreachable because i'm not even getting a grey screen.
Also tried to boot from my Leopard Install CD and that's not better.
by
Add a comment
Try an
external display if that fails too you most likely have a damaged GPU or logic board.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
4 Comments:
external display when it won't boot? why
by
I don't think it can help too.
I'll try tomorrow, if I can find one. If someone else have an idea...
by
by
Tried. Not better. Thank you
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,236
