The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
28 Questions View all
Roomba ignores virtual walls
Roomba 650 ignores virtual wall, but docks OK. I have the VWs that have a two position switch - auto/off.
I have tried new batteries in the VWs and even changed the sensor in the Roomba.
When switched on the VWs blink about every 8 seconds. I have two of them. Could they both be bad?
Update (08/08/2016)
Yes, VW = virtual wall. The VWs that I have do not have a power button that can be pressed down. They are slide switches and have two settings - OFF and AUTO.
I see no other way to reset them.
1 Comment:
@autolab VWs=virtual walls? When you changed or removed the batteries did you hold down the power button for more than five seconds to reset the wall?
by
Add a comment
1 Answer
I have the same problem. I think is a led problem. If you have an other one, please record a video with the phone and look it you see the light of the led.
thanks.
Add a comment
Add your answer
Wes Pike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,769
