The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Questions View all
Android phone massive battery drain
Hello!
I recently factory reset my htc one m8 because it was full of junk. Before, the battery would last me about 1.5-2 days with how much i use it. Now,it barely lasts half a day.
I have tried every guide,every app,and every tip i could find and absolutely nothing seems to work.
In the battery usage section it's just the android os consuming ~ 90% with the apps i use 2-3%.
Right now, it uses more battery on standby than it did when i was using it and it's so frustrating.
Score 1
1 Comment
does phone over heating ?
by
Add a comment
1 Answer
Chosen Solution
Hello Hikary Katsu,
Follow HTC instructions. hope this will help you to fix your M8.
Score 1
4 Comments:
I upgraded from kitkat to marshmellow but the battery drainage is the exact same.Thanks for the update tho.
by
by
it gets a bit hot when it's carging but that's not the problem
by
Then i suggest you to replace the battery (basic physics :-) energy loss )
by
Add a comment
Add your answer
Hikary Katsu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,250
