Why are brakes dragging after vacuum booster change
Replaced vacuum booster and master cylinder, then bled the brakes. After about ten miles, the brakes start grabbing when no pedal is pushed.
You don't say how old the car or truck are or front or back?? Check the front calipers, could be old and hanging up.
Vacuum line from manifold can collapse and cause brakes to overheat. GMC Sierra trucks have been recalled in the past to replace vacuum line.Where the line bends behind manifold. Also old rubber line will start getting soft with age and heat.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 226
