The Acer Aspire D260 is slim and lightweight netbook.
5 Questions View all
Acer Aspire One d250 keyboard not working not even in BIOS!
It was just working perfectly one day ago but when I turned it on today it is not working at all...Iam unable to use it in BIOS...Even I cannot go in the Bios or press f2 or f12 or go into safe mode by pressing f8...Co not even one key is working...I talked to acer support agent and he is saying that it is a Bios issue and is not related to hardware and is asking for $60 to get it solved by their technician..I cant pay them because I dnt have a credit card and also it a big amount ._. and iam not taking my notebook to a local repair shop because there is a risk that they can damage it..!! So please help me :( The model of my Acer Notebook is 'Acer Aspire One d250' !!
Add a comment
Chosen Solution
"If it's not a hardware issue", Get a USB Keyboard and plug it in. That should get you where you need to go..
Score 1
Add a comment
Hi,
These are great netbooks but they are prone to the keyboards failing. I have 2 and have replaced the keyboards a couple of times on both. One way to check is to use a USB external keyboard. However don't forget that the USB sockets don't always startup until windows is fully opened. If the netbook can be switched on and windows starts then try plugging in an external USB keyboard. If that works it is your keyboard on the netbook that is at fault. If you are using win 7 it should allow windows to startup without having to access the keyboard so that you can try this. If you are on win 10 it is a bit harder but it still may work because win 10 starts the USB ports earlier. If it is the keyboard a new one is about £10 on ebay. Remove the old keyboard with an old credit card or similar and push the card corner down between the keyboard edge and the plastic at the top of the keyboard. The keyboard is held in with two lugs at the top and one either side that need to be prised out with the old credit card. When the keyboard is free gently lift it clear but be careful because it is connected by a ribbon cable into a clip connector. Lift the clip on the connector to free the ribbon cable. Installing a new keyboard is the reverse process. Good luck.
Score 1
Add a comment
Add your answer
hearthacker3774 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,732
