Same type of Hard Drive for the 12" and 14" 1.33GHz G4's?
I found you manuals for replacing the hard drive in the 1.33 model: Installing iBook G4 12" 1.33 GHz Hard Drive Replacement, I also found the manual for Installing iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement.
My ibook is definitely 14" running @ 1.33GHz.
My question is: Do they use the same kind/size HD's? And how can I tell which model I have exactly?
Thank You
Score -1
Add a comment
1 Answer
Chosen Solution
They both use the 2.5" ATA or IDE hard drives. Your model number is on the back of your Book. That it the Axxx number. More detailed information can usually be found inside he battery compartment either on the side walls or bottom.
Here are some drives that will work for you: http://www.ifixit.com/search?x=13&y=12&t...
Score 4
1 Comment:
Add a comment
Add your answer
Diana will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 508
