Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1170 Questions View all
iPhone 3G itunes error 1015 broken home button
Hello i got an iphone 3g from a friend that tried to wipe data/factory reset his phone and his phone died which ended up the phone being stuck in recovery mode,the phone is seen by itunes and when i restore it i get error 1015 which means it was jailbroken and propably has an ipad baseband,.now my question is what do i do ,i cant get intu dfu as home button is not working,tiny umbrella sees the phone but dosent give the option to kick out of recovery,other tools failed kicking it out and redsn0w crashes when i try doing ipsw dfu ...is the iphone gone for good?
2 Comments:
No, because you can always get the home button repaired :). Are you able to boot DFU or Recovery mode at all? I used to use RecBoot a long time ago to force boot recovery mode but I don't think it works anymore or I don't remember how I got it working.
by
I have tried a lot of timesto enter dfu but nothing works,the home button was repleaced and didnt help either,it is stuck on recovery mdoe
by
Add a comment
1 Answer
Here is a video on how to fix the error 1015: https://www.youtube.com/watch?v=lKkront2...
If you want your home button to be fixed: iPhone 3G Home Button Replacement
1 Comment:
I managed to get thehome button to work(tested on another iphone 3g butwhen i try getting into dfu the iphone just turns on and goes back into recovery...any ideas?
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 631
