This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Questions View all
Where do you add fluid for the front axle after removing it
Right passenger front axle was removed on a 2001 Ford Escape 3.0L V6 4WD to gain access to the alternator. We assume the axle fluid coming out is ATF fluid on the front. Someone said pour some back in there until it runs out. But wouldn't there be a place to fill it
Add a comment
Chosen Solution
Be careful how much trans fluid goes back in the SUV needs to be running and warmed up when checking the transmission fluid level. consult the owners manual if you just add it you may be adding to much and thats just as bad as having to little
Score 2
1 Comment:
working on my nissan cv axle came off splilling some fluid and i wasent sure wich kind of fluid it was thanks for helping us
by
Add a comment
Hey edwardsdefender51 ,
The front CV axles insert directly into the transmission, Just top off your transmission fluid.
Score 1
Add a comment
Add your answer
edwardsdefender51 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,468
