The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Questions View all
My phone doesnt want to turn on
My phone shutted down and i tried to turn it on...but it just gives the normal samsung animation and then appears the samsung word on the screen...til there everything normal...but after that is supposed to ask me for the pin and the pasword and work normal...but that isnt happening...it just reproduces the animation again and again...what should i do?
Before this my phone used to throw me messages of "google play process stopped working""samsung.apps process stopped working etc etc but the option it gave me was force closure...
Add a comment
Chosen Solution
Adding onto bart's answer
To OP: When flashing a new rom to the phone, you have two options to choose
Flashing with the program called ODIN and downloaded firmware from Sammobile.com. Instructions on how to do so are on Sammobiles website.
or
Doing a system restore via Samsung Kies / (Maybe Smart Switch is used instead) to allow the software to download the correct firmware for you using your provided model number and serial number.
Hard reset instructions are as follows: Take battery out. Wait 5 seconds. Put battery in. Hold Power + Volume Up + Home button to boot recovery mode. When Samsung logo pops up stop holding the power button but keep holding the rest. Release all other buttons once the Recovery Menu with the blue text or other colored text pops up.
Use volume up and down to navigate the menu. Highlight / select 'Wipe Data / Factory Reset' then hit the button to confirm the selection. It will ask you if you really want to do a factory reset. Navigate the selections and select yes to perform the selected task.
Once that's done, reboot phone from recovery. Hopefully this works otherwise use the instructions in this comment to help you restore / reflash firmware onto the phone.
Score 2
Add a comment
Most Helpful Answer
I would try to hard reset the phone.
http://www.hardreset.info/devices/samsun...
You will lose everything but the phone will work.
If that doesnt work i would try to flash a new rom to the phone.
Score 2
Add a comment
Add your answer
Isabela DaVinci will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 129
