Score
Avatar
Reed
343
Asked
iPhone sleep/lock button doesn't work
History
The sleep/lock button on the shoulder of my iPhone (original) only works if you press it INCREDIBLY hard. Like, press the button against a table and lean on it.
It's pretty frustrating. How easy is it to replace?
Edited by
this is a common problem
john,
Post Answer
4
Score
Avatar
David Iwanicki
2.8k
Answered
Accepted Answer
PermalinkHistory
This is a very common issue, usually caused by a drop or strike to the button area, forcing the button mechanism down into its housing and/or bending in the aluminum casing around it.
You need to replace the entire headphone jack assembly (includes the headphone jack, on/off switch, silent/ring switch, volume controls, and vibrator). The part is inexpensive, but working on a 1st Gen iPhone is incredibly difficult.
Look at the iFixit repair steps for this part before making a decision to try this: http://www.ifixit.com/Guide/Repair/Insta...
Might be worth renewing your contract with at&t and getting a new 3Gs.
Score
Avatar
Spikey2
1.2k
Answered
PermalinkHistory
well, it is possible, but HARD
I just replaced the battery on my iPhone, and the steps required are the same pretty much. getting the the shell off is not easy,and I don't see a way of doing it without osme damage.
But it is worth it somehow ...
see the guide in the iFixit teardown!
Score
Avatar
templartyler
13
Answered
PermalinkHistory
I had the same problem with my 3g, but after seeing this the idea to beat it upside down (lock button facing the ground) against the table really hard crossed my mind...it works perfect now. Hope that helps!
@templartyler Your the best man, my iphone was jailbroken in a tethered state so i needed the sleep button to kick into dfu mode. I slammed my 3gs on the table a couple times and walaa' thanks man, most effective and inexpensive solution =P
JNas,
0
Score
Avatar
Crazy
Answered
PermalinkHistory
idk what happened to mine cuz i my bro was using and out no where it was a mark in the screen( from like inside) and the sleep button doesnt work !! its very frustrating.. idk what to do. like my brother said tht he had it in his pocket but i dun think that a pocket could damage the screen and The SLEEP button but i dun care about the screen but the sleep bottom everything work perfectly but the sleep button doesn't.
He dropped it! In his pocket/on the ground but to crack a screen means height... I'd guess the bezel is agape near power button and if you squeeze the screen and case together on the edge there and then push power it'll work. If it does.. Your bro should fess up!
pollytintop,
0
Score
Avatar
kennerbootboy
Answered
PermalinkHistory
I got this problem with my android
0
Score
Avatar
Elaine Eugenio
Answered
PermalinkHistory
@ " I had the same problem with my 3g, but after seeing this the idea to beat it upside down (lock button facing the ground) against the table really hard crossed my mind...it works perfect now. Hope that helps! "
This totally works! Thanks SOOO much!! Sometimes brute force is still the best solution when fixing electronics! :-D
0
Score
Avatar
tori
Answered
PermalinkHistory
beating it is not working please help me! its the fourth generation not 4s!!!!
-1
Score
Avatar
Reed
343
Answered
PermalinkHistory
Since it's also jailbroken, it should be possible to write an applet to sleep/turn off the phone...
well, and the turning on part?
Spikey2,
You can still turn it on, it's just a lot of work. Being able to lock the phone would be useful.
Reed,
Add Your Answer
