Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
You may have a problem with your water pump. See troubleshooting page.
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Why isn't my coffee hot
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 176
All Time: 15,195
1 Comment
It's not hot when I finish brewing
by Adele Martin
