Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Questions View all
My disc tray ony my xbox 1 will not accept discs
The disc accepter will not take a disc like it should I have to forcefully put the disc in with much resistance and that does nothing I still can't play a game or anything iv searched all over the Internet cannot find anyone with this same problem help please
Score 5
6 Comments
Um you open up the Xbox and dust it get all of dust. Because the sensor that notices the game being injected is covered with dust or some other materia/ particles there for it can’t read that your trying to insert the disc once you dust it and make sure the sensors are completely covered in dust it should be able to read and the and the laser lens tray should work normally And it will automatically isn’t the game in normally and Be able to read the game
by
Try pressing the eject button, I have the same problem but if I press eject it accepts the disc
by
Worked thanks
by
Hey if you put an Xbox disc in halfway and press the button to eject it should work in thing it reset it back into position try it
by
the xbox won't let me put my game in usually the xbox is like the force and it forces my disc it won't work. does anybody have any tips for me?
by
Show 1 more comment
Add a comment
Chosen Solution
Sounds like you need a new disc drive. Theses drives are one of the weak points of the Xbox Ones. Every once in a while I've found one that can be fixed but most of the time it's better to replace the drive.
Score 4
10 Comments:
Any idea on the price of one iv seen them vary on eBay would that be my best bet?
by
Ebay or Amazon would work fine as long as they are a reputable seller.
by
For anyone else who encounters this issue: Try a hard reset by pressing and holding the power button on the console for 10 seconds, once it powers off, power it back on. Resolved the issue for me, but if that doesn't do it, repair/replacement is likely your best bet.
by
Ok, so I had this same problem after replacing the disc drive. It doesnt pull as well as the eject button doesnt work. I' ve tried the hard reset several times still nothing and am having no luck find any information on this.
by
How can i put my disc in the disc drive when it not going in the Xbox one.
by
Show 5 more comments
Add a comment
Most Helpful Answer
Hey I've had this problem every once in a while for a few months now and I haven't had to replace the disc drive. I found that if you have this problem, just do the manual eject, even if there's no disc in, then try to put your disc in. This always works for me and it'll keep you from having to buy a new drive for you're Xbox. If this doesn't work then replacing the drive is probably your best bet.
Score 6
3 Comments:
Just did this it worked like a charm! Thx
by
This worked for me also
I tried hard reset and everything else first with no luck..
I've noticed this happens after my son leaves a game cover over the exhaust fan on the top of the Xbox and plays for several hours, generaly after this I have the issue...
Wouldn't mind giving it a clean out too and see if that helps it in the long run.
by
My Xbox one disc tray doesn’t not work at all how do I fix my friend give it to me for a birthday gift
by
Add a comment
Following this video https://www.youtube.com/watch?v=2Z72bds7... solved the same issue i had. Just needed to clean some stuff.
Score 2
1 Comment:
Same here alot of dust and bobbles of Ouse in there so well happy Ty. All working again. Got my Xbox second hand
by
Add a comment
is it bad if you eject a disk while the xbox one is off
Score 1
Add a comment
I have the disk problem as well and I have never acc cleaned it so I’m wondering is it the dust that is causing this
Score 1
Add a comment
I tried the manual eject hole in the side and nothing happened! until I discovered there was no bloody disc in it! now I think I may have damaged it because I have to force the disc in and it won’t read it
Score 1
1 Comment:
I installed a new disc reader now I have no problems, the only thing you have to do is take out the small circuit board from the old drive, hope this helps
by
Add a comment
Where did you pick this disc drive up from I’ve stripped down the Xbox as it was second hand and really dusty. Cleaned everything out. And will boot fine and work fine on Wi-Fi and Bluetooth but when I go to put a disc in nothing happens won’t even acknowledge the disc is there
2 Comments:
Hi, I think I got the drive from amazon, what you have to do is take the small circuit board out of the old drive and put it into the new one, otherwise it won't work
by
Does the disc drive make any noise at all? If so it may be worth tearing it down and cleaning it.
by
Add a comment
Add your answer
Chris owens will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 273
All Time: 80,083
