The Asus Memo Pad 7 Me572C was announced in September of 2014. It is lightweight, slim, and contains many high-tech features. It comes in black, gold, and dark red.
16 Questions View all
Where can I find a guide for screen replacement?
Hi! My Asus Memo Pad 7 has a cracked screen and I would like to replace it. I've read that I may need to order a Asus Google Nexus 7 2nd Tab 2 2013 screen for the replacement, but I am unsure of how to take the screen off, and I've yet to find a guide on this, or any other, website. Could someone point me in the right direction for the screen replacement guide?
Score 2
Add a comment
1 Answer
Chosen Solution
is this a memo pad 7 or a pad HD 7 ? Kinda need to know to help Also need to know if your replacing just glass or complete assembly
and dont order
Score 2
10 Comments:
It's the Asus Memo Pad 7 ME572C (2014)
by
you need to be specific about you glass . The Nexus is a higher end tablet and will likely have a different connector
by
I'm pretty sure the complete assembly needs replaced. The screen stopped responding to touch in the area of the crack, but I don't have many clues to go on besides that, and that the crack was not due to fall damage (so no cables should have jostled themselves loose)
by
Are you going to replace the lcd as well?
by
this guide is enough to get you inside
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
from there all you need to do is replace the display assembly.
by
Show 5 more comments
Add a comment
Add your answer
Noetic Syntax will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,120
