Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36473 Questions View all
Question Closed
Touch screen not working
Hi after having an iphone 3g for about 2 years i noticed that areas of the touchscreen were becoming unresponsive. This wasn't much of a problem until earlier today when the touch area where the unlock slider is located stopped working. Now i can't unlock my iphone so it is pretty much unusable. Other then the touch screen becoming unresponsive there are no scratches/dents/breaks in the glass of the iphone screen I am wondering how do i fix this? and what parts would i use?
1 Comment
Also have same problem, dropped my iPhone 5s and now my touch screen is unresponsive and I can't unlock the phone. My contacts are located on the phone and I would like to get them off before I attempt a factory reset (not sure whether this will fix the screen problem). 3rd party tools like iPhone Rescue and iTunes still require the user to manually trust the connection on the phone which is not possible due to the unresponsive screen. All I'm concerned about are my contacts and I would appreciate any advice on how I can retrieve my contacts from the iPhone.
by
Add a comment
1 Answer
Chosen Solution
just follow this guide iPhone 3G Front Panel Assembly Replacement
you'll need this part iPhone 3G Front Panel
iPhone 3G Front Panel Image
Product
$9.99
2 Comments:
Hi pollytintop thanks so much :D but just to be 100% sure if i replace the iphone 3g front panel my touch screen will stop being unresponsive?
by
unfortunately nothing's 100% sure. you could try a restore on your phone first and then if that doesn't work try digitizer replacement.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 4,408
