My phone is still at huawei startup logo
my phone is not start it is still hang on Huawei logo and after 10 min its atomatically power off
Try following the steps specified here, it will tell you how to perform a factory reset via recovery and restore the system software on the phone:
http://www.hardreset.info/devices/huawei...
Make sure you charge your battery fully before doing any of these.
Initially facing the problem but after a lot of research finally found a proper solution.
Huawei stuck on boot screen, huawai hang on startup logo problem solution
Solved my problem bt this hope this will help you also.
To fix this problem you have to reboot your smartphone.
I perfome hardreset on my huwaei G525-U00 but it is still stuck on huwaei logo
If you can upgrade the Android system, it should solve the problem.
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 158
All Time: 54,545
6 Comments
it is not helpful
by manalotojohn26
I have the same problem too with my Huawei Ascend D1 Quad XL phone.
I tried to hard reset it but, it suddenly stops at “Huawei Ascend”. (It does not stop at its logo, actually)
I can’t turn it off. Even pressing the power key button does not work.
Respect post. Please help.
by Gwapo Swabe
my huawei is blank only showing the logo on screen, cant seem to be able to switch it off.
by ntombifuthi nana
My y9 2019 is hang with logo charger and never turn on please help..
by AirPro Cebu
my NCE-AL00 is hanging with huawei logo and not switch on
by Daniel Retaa
Show 1 more comment
