Repair information for Motorola's Moto X line of mid- to high-end smartphones.
218 Questions View all
replacing the micro USB connector on a moto X
My Moto X had a finicky micro USB connector for many months. Charging involved using specific cords that worked better than others, and then abruptly I could no longer chage the phone. Naturally I suspect the micro USB connector needs to be replaced. I don't see a guide for this or the availability of a replacement part. Does someone have a similar experience and a solution?
Score 1
Add a comment
1 Answer
Most Helpful Answer
The micro USB port is part of the lower antenna assembly. If you're handy with a soldering iron or hot air rework station you could replace the port. Just pull the assembly as directed here:
Motorola Moto X Lower Antenna Assembly Replacement
Score 1
Add a comment
Add your answer
benertle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 856
