The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 Questions View all
rapid power loss power dives from 100% to 3% in seconds
the power reading reduces from 100% to " critical battery power" in about 10 seconds after take off any advice . tried two new batteries same result. Charger charges back up to green within 15 mins. switch off copter and reboot shows the power at a level you would expect (80-90%) than does the same again when you you press take off. any advice ANYONE cheers
Add a comment
1 Answer
Try a different charger and measure the battery voltage if you have a multimeter.
Add a comment
Add your answer
colin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 15
All Time: 102
