Office inkjet printer released in January of 2009. Model number G510n.
39 Questions View all
Printing Everything Black All Streaky and Messed Up with New 901xl In
HELP! Haven't used this printer in a while, plugged it in, connected to internet, printed a test sheet and the color seems fine but the black is barely visible, very choppy and barely there. There is an almost brand new 901xl ink cartridge installed. Alignment test page shows the color but no black and fails after placing test page on scanner glass.
Score -1
Add a comment
1 Answer
Most Helpful Answer
It sounds like your black ink has dried up, or the print head is clogged. You can try this to see if it revives the cartridge, if not you may have to buy a new cartridge. On the printer settings look for clean print head settings, run it and see if that removes the dried up ink. If not, pour some rubbing alcohol in a cup or bowl just deep enough to cover the bottom of the cartridge, where the ink comes out, DO NOT SUBMERGE THE INK CARTRIDGE. Let that sit in the alcohol for a few hours or overnight, in the morning dry the cartridge off carefully because if the dried ink has dissolved you can create a big mess quickly. Run the clean print head again and print a test page. If that fixes it you are all set, if not purchase a new HP branded cartridge, NO REFURBS. If the new cartridge doesn't fix it then you are either looking at replacing the print head or buying a new printer.
Score 1
Add a comment
Add your answer
Kaelea Williams will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 432
