1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Questions View all
The power pads for the MacBook
That's for the macbook air 11" Late 2010.... I'm looking for the power pads from the macbook air 11" mid 2011.
Thx for the help.
Update (02/01/2016)
The only pads I can see (near the keyboard connector) are the ones on the left where the speaker connector is located.
3 Comments
Mattis identify your MBA properly. Late 2011 is not very helpful. It will even be better if you just give your logic board number 820-XXXX
by
The number is 820-2855-A
by
The thing is I only have a green charging light... The macbook air seems to be dead (no fans spinning, no lcd light or chime...) maybe a broken power button?
by
Add a comment
Chosen Solution
Mattis, don't use the once that you pointed out. The pads are marked on the image
Score 3
Add a comment
Look for the power-on pads directly above the keyboard connex cable. Two square pads, horizontally arranged above the keyboard connector (when display hinge is oriented at the top).
Add a comment
Add your answer
Mattis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 878
