The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149 Questions View all
mainboard dead or io dead?
dear sirs im check my air because is dead!
the magsafe led is off, i check with a voltimeter as you can see in the pictures below, and in the main board conector has 14,8 v.
is the io board broken or there is any component in the main board that can i check to determine the fault?
i clean the main board with 98% alcohol and remount all the components.
Many thanks in advance.
Score 1
Add a comment
1 Answer
Facing the exact same issue as you with a 2013 model Air. No power received, strongly suspect the I/O board, but uncertain as to how to test it to the exclusion of a motherboard issue.
Add a comment
Add your answer
antony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 360
