10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
107 Questions View all
Ran out of battery and plugged the charger at the same time
My tablet ran out of battery the second I plugged charger in. This has happened a million times before but this time it got stuck between charging and turning off. First it shows its loading then it turns off and repeats after 10 seconds.
I`ve tried to turn it on normally without the charger and with it. I gave up and let it "load" overnight... nothing.
Add a comment
Chosen Solution
I guess I would say try replacing the battery, it's not a very difficult repair, and you could find a cheap battery, to rule this out as the problem. Something kinda tells me that it's your charger port that's the issue. But that's always going to be more work than swapping a battery
Samsung Galaxy Tab 10.1 Battery Replacement
2 Comments:
Im trying to order a new battery for my Galaxy Tab 4 Model: SM-T530NYKNXAR {written on side of tablet box or SM-T530NN writtenon back of box. Cant find ether anywhere on the net. Can you tell me of other battery models numbers that are compatable? Thanks
by
Found this in an immediate search....
http://www.amazon.com/Samsung-GALAXY-Tab...
by
Add a comment
Hello,
1. go to Recovery and wipe cahshe. Press power button and volume down at the same time and releas power button once u see Samsung logo. If it doesnt help go to step 2.
2. Flash via ODIN new softwear. Download new softwer from SamMobile, put tablet in Download mode and flash ti. your data should stay but if tablet cant boot do factory reset from recovery
2 Comments:
Tried number 1 already but nothing happened. I can´t even try number 2 because all I can see on the screen is black, loading, charging, black etc...
by
hi, so all the time u have the battery on screen which is charging?
than u are facing with false charging problem. it can be due the charging connector or mbo
by
Add a comment
Add your answer
rallee3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 184
