Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
My iPhone fell in the water
My 3G worked for a couple hours then died.
My PC doesn't recognize it, and it just shows the Apple logo.
Should I replace the Battery and lose my warranty?
Any chance I can still Retrieve my Photos?
Score 1
1 Comment
hi Eric
I opened my 3g ,finally found the isopropyl alcohol,now ,should I open and clean even the processors unit or maybe submerge it or just leave it? I opened the 2 covers at 175° and seems they are really stuck.
please let me know
ciao
daniele
by
Add a comment
Chosen Solution
hi, just answered this on your other post. open the phone up using ifixit guide, clean with isopropyl alcohol, allow to dry. check dock connector/cable 4 connection/ if no charge getting to battery and not recognised by itunes this is more than likely the problem. maybe the battery shorted and you don't have enough power to run the phone. they're pretty cheap to replace
Score 2
2 Comments:
HI,
I will clean it at once than if i have to replace what do you mean by " dock connector/cable 4 connection " ?
is it the dock connector part @ 39.95 or anything else?
I couldn't find that" 4 connection " you were talking about anywhere.
by
its this part iPhone 3G Dock Connector
try changing battery. the thing is can't say for definite which is the problem- battery which can't be charged or dock connector which won't.
have had to change both ! good luck
by
Add a comment
You have dropped it in water, so your warranty is already void.
I would follow the advice on cleaning and battery replacement, then dock replacement, or do both.
iPhone 3G Battery Replacement
iPhone 3G Dock Connector Replacement
iPhone 3G Battery Image
Guide
Difficulty:
Moderate
25 minutes
iPhone 3G Dock Connector Image
Guide
Difficulty:
Moderate
Score 2
2 Comments:
btw it's cable connection no 4 (numbers are on all the connectors or you can refer to the guides for tear down/repairs for dock connector/battery which will show you) the connector for the dock you plug the usb into..
by
you're right for the warranty but Apple says if I open it they won't give me a discount phone in replacement.
by
Add a comment
Add your answer
battolla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,234
