Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
291 Questions View all
oil leak towards front of engine
recently had oil change, going down road stop to fuel up check oil,to notice 2 qts. low, oil cap is tight,oil filter is tight, front of engineand all of under carrage is fuul of oil,only lower half of front of engine covered in clean oil...???
Score 1
1 Comment
had a repair shop lift an observre my oil leak problem,they responded; to much oil on engine to see where it had come from,,possibility from front seal....
by
Add a comment
1 Answer
Most Helpful Answer
Get a couple cans of engine degreaser and follow the directions to remove the oil from the engine (make sure you are parked somewhere that wont stain)! Refill the oil and start the engine while monitoring where it leaks from.
Score 1
Add a comment
Add your answer
timothymanie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 261
