1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Questions View all
Installed new battery, but not charging
I recently installed a new (aftermarket) battery in my MacBook Air 11" after the original battery stopped working.
After replacing the battery status reads Replace Now. Not charging.
After some research I decided to replace the i/o board but unfortunately I get the same result.
Suggestions? Should I assume the new battery is faulty? Or should I try replacing the i/o board cable as well?
Update (09/30/2015)
In addition: I have tried two different MagSafe chargers and also reset the SMC twice.
Score 1
Add a comment
1 Answer
Try a PRAM reset holding alt, cmd and R+P on start up until your hear the chime again. This should enable the macbook to attempt to charge, failing that clean the charger ports well with alcohol using a paintbrush/toothbrush - then try again. This has worked for me in the past. Alternatively you may have a faulty battery - aftermarket ones can occassionally arrive without charge.
Add a comment
Add your answer
MichaelV74 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 318
