Repair Guides for Sony Laptops
415 Questions View all
My headphone jack port is not working?
I have a vaio VGN-CR220E. My 3 year old kid was using headphones on the system, he might put the headphone forcefully or what but i noticed that now headphones plugged into this jack do not work at all, unless held at a certain angle, otherwise sound continues to come from the laptop speaker. Can you help me out fixing this problem?
Score 3
2 Comments
Computer, right click, manage, device manager, sound and game controllers, right click on device (was my second one), uninstall, restart computer. This is what worked for me.
by
Ok there are 2 Jack's a red one is the microphone and a nearly invisible 1 is the hp jack. Tried all the software suggestions but failed to suspect the obvious. When I plugged the hp in the right jack no problems....
by
Add a comment
1 Answer
Chosen Solution
This sounds like the pcb board mounting inside the speaker jack has come loose because the headphones may have been ripped out at an odd angle, or too much force was used on them. The board that supplies audio to your headphones via the headphone jack has come loose and may be shorting/not connected. The best way to find out would be to open the laptop for yourself and check. If you still have a warranty, send it back, otherwise this might be a bit tricky.
If you need to open the laptop there will be up to a few dozen screws in the base, underneath the battery case, and under some stickers. You will also have to remove any hard drives to access other screws, there are also screws under your keyboard, however every keyboard has a different opening mechanism.
I would suggest that if you do not have a warranty and are not technically skilled, print out this page and take it to your local repair shop. Most of the time they will not charge a lot (about $50) to repair something like this. If the board is disconnected however and the wires affected are micro-circuits, then a replacement will be required. Still your local technician may be able to help you fix it without replacing.
Good luck:
Patrick Busby
Certificate III: General Information Technology
2nd year Electrical Engineering student
Local repair business; fixing PC's for 8 years
Score 2
Add a comment
Add your answer
shahryar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 13,628
