Where is horn located
Where is horn located on a 2003 chevy cavalier
Have someone blow it and follow the sound. If it doesnt work and your looking to fix it the horn itself is probably the last thing that goes wrong . Check your fuses and as is with most horn problems check the pressure pad in the steering wheel. this is the most common problem with horns.
jtorres12396, you will find the horn on the bottom right front under the fender
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 2,528
