Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Starting up just the 'naked' logicboard
I have a logicboard laying around and would like to test / verify it's functionality.
In my test case, there is following connected to the board:
- Fan
- DC-IN
- Screen-Adapter (for getting some feedback)
- Speaker, left (for getting some feedback)
- RAM (optionally, to trigger "RAM Missing" beeps)
- HDD (optionally, to trigger some Disk-Access)
Two things happen, when the Charger is plugged in:
- Fan begins to start automatically, runs continuously. The fan runs quite silent/slow
- When the Keyboard is attached and the power button is held, nothing happens until button is released. Than the fan begins to run at maximum.
As I know this from working devices, this seems to be the the step before going to normal boot sequence.
Is this behavior already the result of a broken board?
Or is anything mandatory missing?
Score 1
1 Comment:
Your missing your pram battery . What about your heat sink sensors are they attached.
by
Add a comment
1 Answer
You don't really need a sensor connected to the board. The replacement heatsinks for my 2009 model don't come with a sensor connected. You do, however, need a heatsink over the two chips. When I test mine out, I install the bare minimum: HDD, 2gb of ram, fan, heatsink, and connect it to the dc in. Speakers if I need to test them. If I didn't have a heatsink on, the board would overheat and shut down.
1 Comment:
Yeah i have here an White MacBook A1181 2.1 that also won´t turn on.
I disassembled it completly. So my question is what do i need to power on this Logicboard ?
1x RAM - DC - Powercable - Heatsink
Is that all ? Or do i need another thing connected ?
by
Add a comment
Add your answer
wuhulu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 123
