Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
How do I remove coins pushed into the optical drive?
My four- year -old has just admitted to pushing one or more coins into the optical drive of my desk top. Is it worth using a flat knife on it to ease them out or should I remove the drive and then take it apart to get at the coins? Help!
Score 2
Add a comment
Chosen Solution
It's better to remove and open the drive. These SlimLine drives are rather fragile. Pictures of a hairclip lost in a MacBook drive here. Also the work of the owners little daughter. Where would be the Mac repair business without the little ones? ;-)
Score 3
Add a comment
You should be fine just using this guide to remove the optical drive, after which you can simply pick out the coins with tweezers.
Score 2
Add a comment
Depending on how far in they are, you might be able to get them out with something hook-shaped. This might also help: Optical Drive Disc Removal Technique, or Foreign Object Removal
Score 2
Add a comment
Add your answer
matt846 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 5,346
