The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
56 Questions View all
What is the sensor that is spewing oil above the thermastat housing
Its above what i believe is the thermastat housing even thou they say the thermastat is connected to the water pump near the fire was . Also would the connector have a o ring or not.
1 Comment
What year? What engine? Post an image of where the oil is coming out off with your question.
by
Add a comment
1 Answer
Chosen Solution
If this is a 3.1L its probably the oil pressure sender unit They have a tendency to leak . They require a special socket to replace. As long as you have the right socket its an easy fix
Score 1
Add a comment
Add your answer
currieearl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 125
