The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
498 Questions View all
Washer won't fill with water.
My Kenmore 110 washer has trouble filling up with water. Whenever we set it to fill (hot and cold, doesn't matter) it sputters a bit and only pours in a little stream instead of the strong flow. What's happening?
Score 1
Add a comment
Chosen Solution
Water Inlet Valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Low Water Pressure from House Supply
Other Causes and Conditions
How it Works:
If the washer fills very slowly, the water pressure from the house might be too low. If the water inlet valve isn't leaking and there are no other symptoms this problem does not need to be corrected.
Score 3
1 Comment:
Might be a screen at water valve or water hose connection that is partially clogged up allowing only small stream of water to come in. Could also be a defective valve that is not opening all the way.
by
Add a comment
Can also just be because your washer is out of level
2 Comments:
There’s a water droplet button inside my machine. If I press it the water begins to fill. I tested hot and cold this way. Also checked the inlet valves. They look fine. Water pressure appears to be ok when I turn valves on into the machine directly. The machine doesn’t fill when I run the wash cycles. I can hear the hmmm or bzzzz but the water doesn’t pour into the machine. Any idea what to do next?
by
@allenmorton
What is the model number of the washer?
by
Add a comment
Add your answer
Jonathan Rico will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 27
All Time: 3,808
