Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
33 Questions View all
Nook glowlight awake button broke
My nook glowlight dropped and opened up, I did not realize that the button under the outside case for the wake and navigation of the nook is gone. Now I can not navigate the various screens and can only use the on/off button on side of nook, so I can't switch books,screens,ect. This is just a plastic piece that snaps on but I don't know where to find one. Where could I get this fixed?
Score 1
Add a comment
Hey, Cathy.
Unfortunately, I don't know where you would be able to get one of those little plastic buttons, perhaps you could find somewhere to get one 3d printed. Fortunately, that little plastic piece is just there to make it easier to press the small momentary switch that is the actual button. In a pinch, you can depress the button with a pen.
You can find the button by looking at the space where the missing plastic piece was. if you look inside the bottom hole (directly below the screw) you should see a little white dot.
Add a comment
hi,my book shows me only wallpepers,its not respond for turn off
Add a comment
Add your answer
Cathy Wheeler will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,318
